I am on day five of auto-dosing with my Stenner pump. So, I am still trying to get a better grip on my daily losses. When I was doing it manually, I would always shoot for 6, which is the mid point for 40 CYA. But, with the water getting warmer and the days getting hotter, I think I need to shoot higher as the daily FC consumption seems to be growing.
Plus, when doing it manually, I could easily calculate the doses to account for daily fluctuation. Adjusting the run times on the Stenner all the time sort of defeats the purpose of the pump. I think I need to shoot high and adjust run times only if it drifts to 1-2 ppm over the recommended range and continues to rise.
As for increasing CYA, I don't see a lot of benefit as it just increases the minimums and recommended ranges. Although, if daily FC losses rise over 4 ppm, I may bump it up to 50 to see if I can get daily loss back into the 3-3.5 range.
