Hello,
Having an issue with the barracuda G3 vacuum in that it suddenly won't stay flat to the pool floor. The finned skirt, which should lay flat, is lifted about 20 to 30° in the front. All the hoses are good, I replaced the diaphragm, the foot, the fin as well as the float. The weight on the first hose from the vacuum is where it's always been, I've tried moving it but that doesn't make a difference . Suction is great. I can get it to lay flat and work for short periods of time but within 20 to 30 minutes it's lifted again and then just sitting on the pool floor sucking away but not moving.
Have attached a photo of where the front is not making contact with the pool bottom, it's hard to see through the water so I've marked it.
