Within the past 48hours, my FC has only dropped 2ppm. I have a CYA of 50 and it's been cool and cloudy for days. Is this normal? I usually have an FC loss of approx. 4ppm per day..depending on how hot it is.
A total of 4 ppm is sometimes normal in a pool, but going from 4 ppm to 1 ppm daily seems fine, if other variables have not changed.
Are you adding chlorine at the same time? Testing at the same time? Adding the same amount? If you are adding 2 ppm + daily, and loosing 1 ppm daily, your TC should have increased.
I test my FC, CC and pH daily ... at the same time...every morning. I add chlorine everyday...same time (expect for a couple of days now being the there isn't much of an FC loss).
How much chlorine do you add daily and what time exactly? And did you add any in the last 2 days? Important as chlorine additions when the sun is beating down is not a wise choice as a lot is lost to the sun. I always added mine before 7 a.m. and after 8 p.m. in the evening, which was rare. Even sometimes at 6:00 a.m. if the weather was going to be really hot.
Personally, I believe that this is too much of a disparity, even with the weather, but pools sometimes can be very different. Was there activity when there was a 4 ppm loss? This could also make a difference. I am not stating that this is abnormal, just trying to get a handle on why a larger spread.
At very high chlorine levels, you will consume more just because you loose a % and not a flat ppm daily. When my pool was at a CYA of 30, my FC loss was averaging 1.33 ppm weekly. When my levels are about 15 and I test, the loss daily is about 4 ppm, which some can be contributed to testing error.
There could be some items:
1) Testing Error (small, but almost common almost amongst everyone)
2) You had organics in your pool (small amount) and they were cleared up, thereby consuming more chlorine. Even though you test CC of "zero", there still could be something in your pool.
Although, at the end of the day, it really does not matter. Consuming less chlorine is a good thing. Consuming a lot more than normal shows signs of potential trouble. All good at the end of the day.
