Balancing water for SWG per TFP
genlee
46
GA
Installed new T-15 element so I have accomplished Step 1-Salt at 3200
Step 2-Adjust CYA between 70-80. Using my new TF100 test kit my readings were: CYA=30, Cl=5, pH=8.2.
Pool math suggest I add 2 US Gal. of Liquid Stabilizer. Do y'all agree? Any recommend Liq, Stab.?
mknauss
23,544
Laughlin, NV
No real need to raise CYA right now. Your pool water is cold and you are not getting much UV impact. I doubt your SWCG will generate chlorine right now with the cold water temperatures. About April 1 you can bring up the CYA level and your water temperature should be high enough to generate chlorine.
ajw22
12,965
Northern NJ
Note that liquid stabilizer costs twice as much as solid stabilizer. If you don’t like paying for water use solid stabilizer with the sock method when you add it in the Spring.
genlee
46
GA
Thank You!
genlee
46
GA
[/QUOTE]
I like "less expensive". Thanks
