Never understood how to get my vac to climb the walss to clean yet also get the bugs skimmed of the top of the pool by sucking into the skimmer basket? What dial should
go where to equal it all out. Pointing to my photos would help me
Lets get a bit more info from you so we can know what you are working with.
-How many skimmers do you have?
-Do you have a working main drain?
-What kind of cleaner do you have?
I have one skimmer. There are two wholes in the walls at each end of the pool where bubbles/air/water move in and out. Cleaner is Hayward Navigator. It has its own outlet in the pool wall. Now as to the main drain - I have a drain in the bottom of the pool if that is what you are referring to.
Thank you for your help.
Hard to tell from the pool picture, but do you have a weird door on the skimmer? I had surface bug problems and i didn't have any weir doors on my skimmer. After getting them it helped a lot!
