Baking Soda to raise PH and alkalinity
Mshepels
Active member
Jun 10, 2020
34
Bellmore NY
Hi all
I used chlorine tablets in my pool this summer. Now my PH and Alkaline are very low, 6.9 and 20. I added 2lb of baking soda and don’t see PH going up. Any help to raise it please? Thank you very much. I have a 10,000 gal above ground pool.
2lbs of baking soda will raise your TA by 14ppm and have 0 effect on your pH.
You need to get your TA to 80-100 and then your pH will rise. That will require about 8lbs of baking soda.
Reactions: 1poolman1
I’ve read other threads that say baking soda can make water cloudy. The guy at Leslie’s wanted to sell me 30lb of alkalinity up for $70. When I asked him about baking soda he said it’ll work but could make the pool cloudy. What do you think?
Thank you very much
Thank you very much
Uhh he’s just trying to make the sale. It’s the same thing. Follow this link and look at the ingredients….100% Sodium Bicarbonate…aka baking soda 🙄
  • Love
Wow, those salespeople really have no shame. There's a reason we tell people to stay far away from pool stores.
Alkalinity Up is 100% sodium bicarbonate. Arm and Hammer is 100% sodium bicarbonate. It's exactly the same thing.
That is the top level for any pool and you should stop the use of tabs.
It also affects the TA, which is usually not relevant, but it can matter for high CYA and low TA.
Maybe switch over to SWG.
Yes I already stopped using tablets. At this point I just want to raise PH and Alk and close the pool for the winter. Thank you very much for your help.
