First-timer for this forum.
My team and I installed this system in September 2024.
Just finished a $10k warranty and need to answers to make sure this dam well never happens again…
It seems the combination of appliances has a default of 200-500 milivolts being back-fed and trips the gfci breaker.
With the last cold snap (January of 2025) the 50 amp double-pole gfci flipped without apparent cause. It services the PoolSide Tech, Jandy variable-speed, Raypak E3T, CMP (UV/Ozoneator), and the Intermatic 300 powering the 1/2” colorlogic 80.
After having replaced all impacted plumbing, it appears the Poolside tech and the Intermatic are incapable to allow the independent gfci breakers to function, they do function with standard breakers though. (Concerning… )
I have scoured the entire system. I replaced the 50 amp gfci with a standard and installed separate gfci’s for all appliances. Had 2 different electricians look at it. I pulled all the wires out of the conduit hoping for a jacket breach on the lines/loads.
The most rational thing I can come up with is that the step-down transformers for the Poolside Tech and Intermatic have a slight feedback causing the dripping gfci.
Please give me your input.
Thank you in advance.
Jim
Jim
