Autopilot Nano with PPC2 or PPC1
Heavenlytunes
179
Nassau, Long Island NY
Autopilot Digital PPC1 (RC-35)
I just noticed on TFP has options Autopilot Digital Nano PPC2 or Autopilot Digital PPC1 (RC35)
I have a Nano but PC1
Did the installed the wrong one?
We recommend you get a SWG whose cell capacity is 2X your pool volume. For a 25K pool you need a 40+K cell. I would get a PPC3, 4 or 5 cell system
The Autopilot cells are:
  • PPC1 - 28,000 gallons
  • PPC2 - 32,000 gallons
  • PPC3 - 50,000 gallons
  • PPC4 - 60,000 gallons
  • PPC5 - 80,000 gallons
At this point I can't ask the PB to change it. That means I'll be $400 to $500 out pocket for a new one PPC2 or PPC3.
I still don't know the exact gallons I got.
I keep getting all different answer because of the freeform shape.
But let's just say is 20k to 25k would the PPC1 do the job at full setting?
Thanks in advance
You can check this with Pool Math in the "effects of adding" menu from the top left button. If I plug in your 25K pool and set power to 100% it will need to run 7.75 hr to generate 2 ppm FC. See below. During hot sun FC demand can be 4 ppm. At that point you're running 15 plus hours. This is one reason TFP recommends sizing for 2x your pool size. For reference my unit is sized for 30K on a 12800 gal pool. I run 50% power for 6-10 hrs depending on the weather and swimmer load. I have a screen enclosure so my pool FC demand rarely goes over 3 ppm.
Will it work? Yes, at least to start with and if you go this route I'd make sure you have a VS pump so you won't have a huge power bill. All you need is enough flow to open the flow switch which is often half speed or less. As the cell ages you'll probably have to run 24 hr to keep up. How long does that take? Maybe a couple of years and this depends a lot on how much FC demand you actually have plus how well you manage your chemistry.
Why can't you ask the PB to change? Late changes because you change your mind are different from a PB that under-sized the equipment. He should have leverage with the supplier to be able to make the exchange at reasonable cost.
Chris
Reactions: Heavenlytunes
Chris
Thank you Chris
Chris
Thank you Chris
I recalculated using the pentair pool volume calculator and it looks like between 19k and 20k
Weird I have 15, 16 and 17ft width x 34ft.
I have a section with inside step/shallow and deep end 7ft
for reference, I have a similar shaped pool that’s about 34ft by 16ft with an 8ft deep end and it’s about 27k gallons, but that calculator comes up with 22700 Gallons. i had a pool guy come out and measure the perimeter with a rolling “tape measure” and calculated it that way. He came up with 27k gallons and the chemical dosing has turned out really close to matching that. so be careful with those estimators.
Thats what I don't understand. My PB called the manufacturer today and reconfirmed that the amount that pool holds is about 20k. With an 8ft x 4ft depth
As a double check make sure you have no algae with an OCLT then add 5 ppm liquid chlorine with the swg off based on what Pool Math calculates for a 20K pool. See how well it matches.
