Your Circuits look ok, so the problem must be something is mis-wired, or your circuit card is bad.
Show me several pics of your equipment pad, so I can see the pump and the inside of your EasyTouch so I can see the circuit breakers and your relays. And one of the front of your EasyTouch's main panel with the buttons so I can see what EasyTouch you have.
I assume you have a VS pump, so show me your pump speeds.. Like this..
