I have been using TFP for almost 4yrs now and have had wonderful results with pool chemistry! Now it's time to tackle automation
Installed an iAqualink system over 3 years ago and then replaced the pool pump to Intelliflo VSF after previous one died. Will be following instructions on TFP to adding the Intelliflo VSF to work with IQ20-A based on the following
and will post result or ask for help if I have issues.
The question on Automation is as follows: I have the following from Jandy: All Button Control Panel with 2 JVA(Pool/Spa Combo) + 1 JVA for Solar. My understanding is that I have 1 JVA left that I can add via the "Cleaner" connection being that Intake, Return and Solar are being used for 24VAC. Aux1, Aux2 and Aux3 are used for Jet Pump, Light and Colorwheel by driving a 24V Relay for to provide 120V AC to the Sources.
Am I able to use the 24VDC that I have left over for Aux4, Aux5, Aux6 and Aux7 to drive any Valve Actuators being that this is 2 wire 24vdc vs 3wire 24vac? If yes then any recommendations on Actuators that work with 24vdc?
FM
Upgrading to iAqualink IQ900 with a IntelliPro VS-3050
I must have searched for hours looking for information to help me with upgrading from the Aqualink RS PDA power control to the new iAqualink. The PDA PCB died and it was a lower cost option to upgrade to iAqualink than to replace. Unfortunately Zodiac doesn't publish publicly the installation...
www.troublefreepool.com
FM
