- Oct 7, 2024
- 10
- Plaster
- Pentair Intellichlor IC-60
To preface this, we had several short power outages from hurricane Helene and I don’t know if the issue started at that point or a couple days later. About a week and a half ago I noticed my hot tub wasn’t overflowing into the pool. Initially I thought my pool person hadn’t sealed the pump basket lid completely and it sucked air and ran dry, which has happened before. I checked the pump and it wasn’t running but the lid was in place and the basket area was full of water. I opened my panel and it said the pump should be running so I turned off the breaker for the pump and waited about 30 seconds and turned it back on and the pump came on. Next day I noticed the same issue and went through the same sequence and it started back up. 3rd day it still wasn’t running, I checked my wired indoor panel and it said “no comm”. Went out to the panel, flipped the breaker off and back on and the pump didn’t start. I opened the panel cover on the pump and pressed the start button and it started up. That is still the only way I can get it to turn on at this point. The indoor panel still says no comm. Every time the pump isn’t running I go out and the intellichlor ic-60 is on and my pool lights still come on at night. What can I check or is it time to replace the whole panel or pump? Pics attached of what I have.
Additional thought that may or may not be related. There have been several times over the last month that I have noticed the intellichlor circuit breaker has tripped.
