Apologies for a long post; hopefully this has enough background / detail to answer most questions.
First, just wanted to say how great TFP is. I'm a new hot tub owner and after months of frustration with the frog system and cloudy water, I found TFP in January and followed the dichlor - chlorine method. My TA and pH have been rock solid and a couple of ounces of chlorine each day have kept the water crystal clear. I'm amazed every time I open the cover.
Now I'm looking for an automated solution to take FC readings that will ultimately be used to automate chlorine dosing so that I can go away for more than a couple of days. I have a home automation system and have found several people who have used probes and sensors to take readings that trigger automations to control dosing pumps. There are a ton of resources for doing this with hydroponics, such as for pH but not for FC. Some have suggested calculating FC based on ORP, pH and temp. I reached out to Atlas Scientific about using their sensors and asked what the calculation would be. Despite selling a kit specifically marketed to pool owners that comes with ORP, pH and temp sensors, I was told that such a calculation doesn't exist, but ORP can be used as an indicator. Several posts here go into details on that, but I've struggled to find a direct answer to my question among all the technical details.
Here's what I want to do:
* Use continually submerged and hidden sensors (i.e. pH, ORP and temp) to take automated readings
* Based on the readings, calculate an appropriate amount of chlorine to dose using an automated dosing pump
* Sufficient accuracy to allow ~10 days away. While home, I will manually test the water regularly
* I'd prefer a DIY solution
If there really is no way to accurately determine FC levels (automated, without an expensive FC probe), my second approach would be to find a static amount of chlorine to add each day that would keep it in the 3-5ppm level without use. It's covered, under a deck so no UV concerns. Then when we use it, I would manually add more chlorine as needed.
I would love to know if anyone is calculating dosing based on probe readings. I know this capability exists as there are a few products on the market, such as Sutro. Can anyone help me get over the hurdle?
Thanks in advance!
-Brian
Thanks in advance!
-Brian
