Attach pergola to patio -- worried about gas lines under patio
courtHouston
3
Tomball, TX
We are intending to attach our 10x12 pergola to our pool patio this weekend. My concern is knowing that our pool's fire feature has a line that runs underneath the patio. Is it safe to assume we can drill into the patio for a 6.5" titen bolt? I'm seeing most Houston, TX regulation stating gas line must be buried 12 inches below grade.
During construction in 2017, I did try to document each stage with pictures. I'm attaching the best one I could find showing piping heading under the patio (my shadow represents main part of patio). Second pic is dirt area that is now under the concrete patio. Third picture shows the patio type.
Located Tomball, TX (Harris county)
Do this. When the guy comes out just tell him what you’re doing and he’ll mark out the gas line location. Concrete tends to be 4”~ deep and gas lines are supposed to be deeper, but the drill bit doesn’t always stop at the required depth.
811 will take a full description :
'Drilling support holes for 10x12 pergola 5ft off back door' (etc).
If they deem the heater line to be privately owned, they can probably recommend a local company to hire to locate it. Its tricky because technically anything past anyones meter is customer owned, but none of the utilities want their service damaged so sometimes they mark it and sometimes they dont.
Also, in this and many other circumstances, I consider a $20 bill at first meeting to be an 'attitude adjustment fee'. Hey man !!! I'm (insert name here) and I'm buying lunch today. *gives $20*. Anywho this is what we're doing........
When I did it here (not Texas), the guy came out and had no idea whats the specifics were and wanted to know the general area of what was needed and then marked out everything that was in that area. I’m assuming he’d have marked absolutely everything if I hadn't been there to limit the scope for him.
When you place a ticket with 811 you are supposed to clearly describe the area of work. It is also appreciated if you mark out the area of work with white paint. Having said that, locators realize the difference between homeowners and contractors, and Dig Safe would much rather you call and not have the work area not clearly marked out, than not call at all.
Some utilities send a locator on every ticket, but most use their records to determine if a person needs to be dispatched or not (cost savings). If you say "I am drilling in the patio in my backyard" it is a possibility that the electric, gas, sewer, water, and communications companies will all look at their plats and say "we have no buried utilities in your backyard - you are good to go" without sending a locator tech. In some states, the utilities do this, in others the contract locator takes the brunt, in some the utilities send their own employees to do the locating, and in some areas the 811 contractor will provide the triage service to the utilities (for a low low fee of course).
The upshot of this is , you may or may not get a locate tech out there, and if so, they may or may not do you a solid by locating private utilities.
Oddly enough, this along with soils engineering is one of my past jobs. I used to manage the contractor that did mark outs for a large telecom company in NJ and was part of the NTDPC (National Telecommunications Damage Prevention Council) and CGA (Common Ground Alliance). It's been a few years, but not much has changed
My thoughts at the moment are to construct the pergola (without attaching it to the concrete decking) and then call 811 out so they can get an accurate look at where I want to place the pergola.
