Are sweep elbows/90s more useful on suction side or pressure side
everthustodeadbeats
Active member
Jul 12, 2023
32
Detroit, Michigan
If I have a limited number of sweeps versus regular 90s, should I prioritize using them on the suction side (before the pump) or pressure side (after the pump)? Or does it not matter, and the head loss is calculated on a system-wide basis, no matter where any individual fitting is located within the system?
Using them on suction is better than return.
However, make sure that you are using the correct size pipe.
Pipe Size and Flow Rates.​
You want to keep the water velocity below 6 ft/sec on the suction and below 8 ft/sec on the pressure side of the pump.[7]
Pipe Size6 ft/sec8 ft/sec
1.5"38 GPM51 GPM
2"63 GPM84 GPM
2.590 GPM119 GPM
3.0"138 GPM184 GPM
4.0"235 GPM312 GPM
Thanks. I don't know what the flow rate is. The pool is 50 years old and everything is underground except for the pad. I am replumbing my pad which is currenly 1.5" pipe with a lot of turns and convoluted pathways. I am changing the pad plumbing to 2" pipe and also simplifying the path with fewer twists and turns. Hopefully I will see some marginal improvement, and at least I don't think that whatever changes i make will make the flow rate worse.
Another question: I have an existing 2-way valve that's glued into the 1.5" line. The valve supports 1.5" inside the fitting and 2" outside the fitting. If I cut the outlet flush with the fitting and glue 2" around the fitting, should I remove the existing 1.5" pipe that's glued into the fitting (either with a heat gun or fitting saver drill bit) or just leave it in? Even though it is restricting the flow a little, at least it's smooth.
Or I could just leave 1.5" pipe on both ends and add a bushing after the valve to expand the line to 2". What's the best option?
Either way is fine, you won't notice any difference in that short distance.
Reactions: Darin
