Hi, long time lurker here. Thanks for all the information over the years, but now I've run into my own problem.
I purchased a used AquaTrol system with cell last year. The system worked reasonably well, but it was obvious that the cell was aged, and even more so now. I'm looking to replace the cell. However, when shopping, I see claims that a cell might be compatible with AquaRite and no mention of AquaTrol. Furthermore, many of these claim that software revision 1.50 or greater is required (for smaller cells?). But again, that is for AquaRite and I don't know how those translate to AquaTrol. Finally, what is the difference between "T-" prefixed cells and "GLX-" prefixed ones?
Here is the GLX-CTL-TR-RJ controller, as we see it is running revision 1.45:
And here is what appears to be the current T-CELL-5 (or equivalent):
My pool water volume is approximately 14,000 gal. I thought the T-CELL-5 is only compatible with AquaRite, Aqua Plus, Aqua Logic; I never see AquaTrol listed. I think a T-CELL-15 should work and should have a longer life. I may need to check a jumper to make sure it is configured properly, but again I never see AquaTrol listed in descriptions. I'm fairly confident the non-5/15 cells (e.g: T-CELL-9) require newer firmware. But, what about the GLX-CELLs? I'm just looking for clarification before dumping a few hundred dollars. I wish Hayward would provide a controller/cell compatibility matrix.
Pardon my ignorance. Cheers!
