Hi all -
My Hayward SwimPure Plus system is not producing chlorine and I'm trying to figure out if it has finally died or if it's fixable. The unit is from 2013 based on the serial number (3A13081-xxxxxx). I did the thermasistor fix 2 summers ago and they look fine. The cell itself is about 4 years old and has been recently cleaned. Pool is 20x40, 36,000 gallons.
What I'm seeing:
- TC and FC are both zero - which is how I know it's not producing chlorine - and the pump has been running 24x7 at 2500 RPM this week. I've triple checked with a trip to Leslies, some test strips, and my Taylor kit. Flow is good, sand filter has been backwashed in the last week, pressure shows clean.
- The SWG is showing the Power and Generating lights green, all others off.
- Knob is set to 75%
- Instant salt is 3000
- Average salt is reading 3300 (Leslies tested at 3200)
- Temp is 81
- Volts is 24.7
- Amps is 5.61
- Cell is T-15 (which is correct) and AL-0 and r-1.58
It's been set like that all week. What's interesting, is when I move the SWG to Super Chlorinate (100% essentially) or move the dial to 100% and leave in Auto, the Generating light goes dark and the Super Chlorinate light does not light. Amps drops to zero. Based on the above, it looks like the SWG is generating - volts, amps, and salt are all in the right range and the controller PCB is doing what it's supposed to do - which confounds me. Any suggestions?
A friend has a T-15 cell I can go get and troubleshoot with if it sounds like it's worthwhile, but it's a couple hour drive to get it.
What I'm seeing:
- Temp is 81
- Volts is 24.7
- Amps is 5.61
