So this week my Aquarite controller quit working. I tried to replace the limiter (which have successfully done in the past) but no dice. So I purchased a board off of Amazon, didn't work.
I have verifed that the power is coming in at 240 and everything is hooked up correctly but it will not work.
My pump will not come on either but I am not sure if that has anything to do with the controller. Both are connected to a timer box which, as mentioned, is sending 240 out.
Any thoughts? I have run through the troubleshooting guide with no luck.
