My AquaPure keeps resetting the chlorine production rate to 35% after it turns back on. Regardless of what the previous rate was left at, when the pool pump turns back on (or when breaker is turned back on) the AquaPure's chlorination rate resets to 35%. I imagine the breaker turning off or the pump turning off (which shuts down the SWG) is resetting any saved settings for the AquaPure. Is this intended behavior? It's very inconvenient.
(Update: Talked to Jandy support--they weren't helpful. Then talked to Pinch-a-Penny, they initially thought it was due to the wiring. They called their Jandy representative while working on it, the Jandy representative told them it was a bad circuit board.)
