Hello all,
I recently upgraded a Jandy Aqualink RS4 to an RS8 with wifi. In the programming, I see the standard on at X off at Y programming ability but I'm curious if there is a way to program only an "off a Y" program. The pool is in a vacation rental and quite often the guests forget to turn off things like the hot tub spa and it'll run all night. Is there a way to program in a "shut off at 11pm" program, short of setting up an "On at 1059p and off at 11p" program? I have an AC unit doing this through a smart things hub, but it doesn't look like Aqualink will integrate with that.
Any advice would be appreciated. I don't mind manually going in and shutting stuff off, I'd just prefer to not have to.
Thank you in advance,
Ryan
Ryan
