I want to add my name to those who had success solving rapid pump relay cycling when the Aqualink goes into Freeze protection mode. The fix to this apparent software bug is to add a "device" to freeze protection in the controller menu. In my case, I had a spare Aux channel that has no function. Now when freeze protection mode initiates, the pump runs for a minimum period of time....like 15 or 30 minutes, even if the temperature increases.
I learned about this fix on TFP from an old post. Another poster, who did not have a spare channel, added the spa blower and turned off the blower motor breaker in cool weather.
You can also lower the freeze protection initiation temperature to 34 F in the freeze protection menu selection.
Actually, I experienced this issue first at temperatures well above the 38 F freeze protection temp. I heard the pump randomly turn on momentarily. When it got much worse, I was fortunate enough to look at the controller screen where it reported going into freeze protection mode. But that message disappears quickly when a second device is not assigned, so I was fortunate. Even though the air temperature appeared correct, it must have had some droops. I ordered another sensor but then used contact cleaner on the wires and screw connection of the existing one. This cleaning operation resolved the random pump starts, but the issue still remained near the freeze protection threshold, until another device was assigned.
