- Jun 7, 2017
- 9,107
- Plaster
- Jandy Aquapure 1400
I got my Aqualink WiFi installed and working and now the question is what do I do with it? I can't seem to do anything accept very basic stuff. Start and stop the pump but I cannot control the variable speed. And the variable speed, even with the PDA is clunky and dumb. Everytime you go into a new speed, it takes you to the RPM screen so you can set it and it is never what you previously put it at. Also it starts and stops the heater, lights, waterfalls, etc. So far it is a huge letdown it seems like I need the PDA to do anything meaningful. Is this how it is supposed to be?
Also do the motorized valves suck as back as I think they do? They are basically on and off settings. No in-between for balancing but I am told the setpoint can be wherever you want. But if the pump is at a different speed, tough beans it will only recall what it is set for.
The light is very poorly programmed and though out as well. There are no custom settings you get what they give you. If you switch from one thing to another the system goes through a bunch of stuff before it gets there. It just seems like 1970s programming. Very lame!
I so far am sorely disappointed by Jandy stuff (all of it). Are other systems better?
