Aqua Rite system (2009) Jumper location to change from t-5 to t-15 cell.
Matt Pozza
6
Ottawa, On
I am pretty sure my older version aquarite system is set for a t-5 and I am using a t-15. My salt readings are displaying 4800 when actual is 2900. It occasionally locks out for false high salt. The problem is I can not locate the j4 jumper on the PCB. Can someone please direct me? Photo of my board attached The unit is a G1-939013a. Firmware is v1.45. “Goldline controls 2009” printed on the board. I would be most grateful for any help or suggestions.
Hi,
I’ve been trying to troubleshoot my Aqua Rite G1-939013a with version 1.45 firmware. I am using it with Hayward t-15 cell. It is showing very high false salt readings(4800 reading, 2800 tested at pool store) . I’ve swapped out the cell with my neighbours t-15 and it behaves the same. I suspect the board is set for a T-5 cell thus the false high readings but I cannot find the j4 jumper I read about on another thread that sets the cell type. I have attached a photo of my board. Can someone point me in the right direction? Thanks for your help.
The rain finally stopped this morning and I pulled off the display ( I did not realize it was so easy). I found J4 but there is no jumper or pins... just solder points (see photo). I have soldered PCB previously but I just wanted to confirm I should jump these pins to set the board to T-15. I assume I should use a wire as opposed to glob of solder?
model number by the barcode is AQ RITE CUL
Fixed! I just soldered the pins together. Tip: Have a decent voltmeter handy and measure the resistance of your solder using the pins at the opposite side of the board as your solder. My first try I had 12 mOhms of resistance and the system still operated in T-5 mode. On my second attempt I made sure I put adequate heat to the pins for a good solder and had 0.4mOhms resistance and the system now accurately displays the salt level! Thanks!
Reactions: JamesW
