Here's the installation manual for the polaris booster pump that I have -> https://www.hydropool.com/downloads/polaris/PB4-60Manual.pdfI think I have to learn more about pool plumbing, that's what I think!
Pages 2 and 3:
agrees with 1poolman1, though it doesn't explain why. Sounds like you two figured it out. My bad.
I had it right for plumbing with and without heater, but not when a spa is involved. It mentions keeping the booster feed 3' away from the heater, so that is a concern. The manual doesn't mention the SWG, but I think I'm right about that, too. An SWG is supposed to be last in the chain, so that the super-chlorinated water goes directly to the pool, and not through anything else. I guess there is no choice when there is a spa involved.
I think wherever the tap is, you have to protect one thing or another with the automation. No matter how it's plumbed, you can't run the spa and the vac at the same time. I don't have any stats on what happens running an active SWG through a booster, but I don't imagine doing so is good for it. Perhaps you can program around that, too. Run your vac cycle each night when no one is likely using the pool or spa, when you're not running SWG or heating your pool. I run mine at 4:30am, when there is no solar heater or SWG action. That is for reasons of safety and vac performance (neither of which apply to a pressure-side vacs, but something you'll have to contend with if you ever switch to a suction-side vac). It is also something to think through if you're still considering the 24/7 club.
Thanks for the lesson everybody!
It too mentions three feet downstream of the heater (which I think I actually meet, or very close to it), and it also mentions being upstream from and higher level than a chlorinator (the chlorinator it pictures is like a tab feeder -- which is what I had in that spot before -- I'm not sure if the same would apply for SWG). But that said, the plumbing options they show in their diagram show exactly the way my system is plumbed (option 3) as a suitable option and the return lines are going into the ground right after the return line is tapped so I'm not sure how they envision plumbing in a chlorinator underground, etc.
But anyway, it is clear there is not a perfect solution, at least in my situation without some significant reworking.
