- May 15, 2018
- 39
- Plaster
- Pentair Intellichlor IC-60
Hi.
Just started my first 2 weeks with the Pentair IC 60. I will describe my setup and what readings I am getting and then I will ask my questions after that, if that is ok.
Cell is plumbed in after heater, before the pipe heads back to pool. No flow issues (thank god). It is powered off the Pentair power box for that cell, which in turn is connected to my Intermatic time switch. SWG running 24/7 at 10%, I lose FC 0.5 in a 24-hour period. Switched to 20% and am currently trying to figure out what on/off time I need to get it somewhat steady at FC 6 (for my CYA reading). My readings are a bit erratic, going up faster than I thought at times, other times dropping when I didn't expect it.
I am not loving that my SWG is now dictating how long I can run my pump (i used to like running it 24/7 personally). Based on the numbers it would seem that my pump will be off around 10 hours a day if my FC readings start to come back the way I think they will. I live in NY state, so later in the summer/autumn, my heater is needed more often, and needing it off for 10 hours because of the SWG will not be ideal. In hindsight, I wish I had been more aware of separate timers or timers that can operate more than 1 device.
1) Does anyone else operate a Pentair or any SWG for that matter with just the % increments that it offers and then adjust with a manual timer? It would seem like I will constantly be adjusting it.
2) Intermatic has a 3 circuit timer (Model#PE153), and i see Pentair has the 523317 INTELLICONNECT. Does anyone use any of these or something else to control their SWG? I know the latter has an app that gives you access to the % increments between the ones offered just on the cell itself. It also allows you to set times as well as set pump times, as it has several circuits.
3) My salt level is 3400. My cell says to have it at 3200-3400. I can taste the salt, its not particularly strong, but its there. Is that just par for the course with salt pools?
Thanks for reading, I just wanted to check in and see if my current experience is typical and just the way it is with SWG's, or if I'm not setup right.
John
John
