People up north: "no big deal"
People down south: "its going to be how cold?!?!?"
Marty was that really necessary!!! LOLMid 70's here --
Just thinking about you all ----------
So check my logic on this please. In the Dallas area people rely on freeze protection, including me. We have a 3 day stretch where it looks like we will dip down into the teens and get a few degrees above freezing each day. We were in the 70's earlier in the week and chances are we will be back there shortly, so I would really rather not spend superbowl sunday learning how to winterize for a 3-day stretch of weather.
I'm really only worried about a contingency plan in the absolute worst case we lose power in the middle of the night when it is in the teens. If that were to happen, this would be my course of action:
- Turn off the breakers
- Drain the filter via the bottom plug, leave the top pressure valve open as well
- Drain the pump via the bottom plug
- Tarp the equipment
Besides freezing my butt off in the middle of the night doing all of this, anyone see any glaring issues with this contingency plan?
I'm going to reiterate Leebo's comment to be prepared.... When its warm out.. you need to prepare and move someplace that stays warm out.. it was 70-ish for me too on Stupid Bowl Sunday!Please make sure to spend a few minutes while it’s warm’ish to learn how to winterize your pad. For sure you can run the equipment with weather that cold, just prepare for worst case. If power goes out due to ice or whatever your plumbing will be full of water and will freeze in time. Just be prepared to drain everything.....just in case. Don’t wait until it’s 10° to learn.
I would hope that we would not have to do anything with the skimmers. I get it up north that you want to protect the plastic skimmer from the expansion of ice. In the event we would lose power and start having to drain water from equipment, I would think that we would not have to worry about the actual pool freezing over and damaging the skimmers. If my pool does freeze over, I'm putting up a for sale sign and moving somewhere warmer.Do we do anything with the skimmers? We have a heat pump...wondering if the water will drain out of it if we drain the filter and pumps as you describe?
Even if it did freeze over, it would not be cold enough for long enough to create thick damaging ice. For you to get an inch of ice would be a once in a lifetime event and that inch would have plenty of room to expand upward. The rest of the time you would be hard pressed to even get a thin crust like layer of ice.I would think that we would not have to worry about the actual pool freezing over and damaging the skimmers
