Just want to check and see if anyone thinks poorly on this setup. Did some forum reading and most things revolve around timers which I don't use.
Picked up an RJ60. Just jumpered it to 110V.
My pump is wired to a plug that goes into a locked GFCI outlet (has a outlet lock box over it). Plug is wired off a switch.
Eventually I want to put a sub box out in the shed and move everything over to 220 but it's a dedicated line aside from a light in the shed.
Going to wire the RJ60 to a plug and put it in the outlet with the pump.
If the GFCI trips or the switch is turned off, neither pump nor SWG will run.
In my mind that's safe enough between running them both off the same circuit and on a locked outlet to cover my bases in addition to the flow switch.
Just want to double check with the pros.
