- Nov 12, 2017
- 11,883
- Plaster
- Pentair Intellichlor IC-40
The DW air gap mounted on the sink is a type of back flow preventer that keeps DW waste from being sucked into your plumbing should a back flow event occur (like a busted water main). It also doubles as an overflow for the dishwasher should anything after the DW waste line back up: like a clog in the drain or a disposer that is full of crud. It won't address the venting issue.
I think you're good-to-go: one trap, AAV, done.
