- Jun 5, 2011
- 1,316
- Plaster
- Jandy Aquapure 1400
I’ve had an on-going minor cloudiness issue for the past several weeks. My water chemistry has been great all summer and I had a filter issue that led me to believe that the cloudiness was a DE leak. I’ve replaced the filter grids and the air relief assembly, but the cloudiness remains. I raised my FC level to 6 several days ago just to see if it would change anything and the water did appear to clear up some. The water has had more debris recently due to rains, leaves falling and cedar elm seed production, so it’s time to get the cover on, but I’m planning to SLAM just in case I have an algae problem. My current test results are:
FC 4.5
pH 7.6
TA 70
CYA 70
CH 300
Salt 3200
Last night, FC was 5, so OCLT yielded a .5 drop. There was no FC loss in a test just a couple of weeks ago. I suppose the current FC loss could be due to the debris, even though I’m removing it pretty often.
So given that my only indication of a problem is slightly cloudy water, is there any risk in doing a SLAM? Assuming risk is low, how long does it usually take to get FC levels back down to normal once water is clear? I want to make sure everything is ok before putting the cover on. Last question: can the large amounts of bleach required to get to SLAM level be added all at once (understanding that it needs to be added slowly)?
Thank you!
FC 4.5
pH 7.6
TA 70
CYA 70
CH 300
Salt 3200
Thank you!
