- Aug 12, 2022
- 119
- Vinyl
- CircuPool RJ-45 Plus
There are times that we only have the fountains running with the other return closed off, especially when the heater is on as people (my wife) like to site under the pouring water. I would like the SWCG to still be producing Chlorine when that is the case as it can be in that state for several hours.
I thought maybe your design had something to do with the aeration/cavitation from the jets causing the chlorine to off gas faster.
Well, since I am doing this mostly for my wife, that's a great consideration. JK, it's for me too, and kids, and grandkids.![]()
That's why I'm here, trying not to screw this up too bad. I have socket 90's and T's not DWV, with 2" pipe, once the system is pressurized how much will it be noticed? I'm not worried about the fitting holding, so the issue would then be flow rate which would be a minimal reduction between 90 socket and sweep?Another nitpick per your request sir, your diagram shows sweeps instead of 90s.
If this is your intention, just make sure they aren't DWV sweeps. We see this from time to time.
You'll need to source proper Sched-40 sweeps and you won't find them at bigbox stores.
