Hello!
So far, in central Indiana we have had a pretty mild winter. It was around 70 today. Our pool has a leak and I have added water on and off through the winter. Our liner is to be replaced and pool stairs where leak is repaired as soon as warm weather is consistently warm enough. Hopefully next month.
The last I talked with my pool company they suggested if we thought it was low to add water through the skimmer as I had mentioned it took a few tries to get the cover open when water was low. So, long story short I added water today and then opened the cover and I most likely added too much. I added pictures to show. Weather is to get cooler, next few days mid 30’s to 50, and this weekend high 20’s to 40’s. Since there is a leak I am guessing level will continue to go down, but I don’t know how fast. Should I do anything, or should temps be Ok to avoid problems?
Thanks!
Thanks!
