Salt feels better to our skin and eyes because we are salty beings. Our tears have 9000 ppm of salt. A salt pool has 3000-4000 ppm of salt. The ocean has 35,000 ppm. There are lots of folks who add salt to their pool to improve water feel. And, of course, it is convenient because you don't have to haul and add Chlorine to the pool.
Long time reader, 1st time poster here. Thanks to all at TFP for the plethora of info that has helped me many times from pre-construction through the last 9 months as a new pool owner.
pooldv - notice you have a SWG and OK flagstone. Is your stone sealed? If so, with what and how often? If not, have you not experienced any damage or erosion from the salt level necessary for a SWG? There are numerous threads here on the subject, but I chose against a SWG due to the potential risk to my OK flagstone. I've second-guessed that several times to date.
I started with manual dosing of bleach and faced challenges with FC levels until I found my PB failed to add CYA at startup as they were supposed to. I eventually got lazy in the summer and relied on pucks for about the last 6 months, to my detriment. Pool was crystal clear all summer, then about a month ago algae started appearing on the walls and benches of the spa, and a bit on the walls of the pool. Brushing and supplemental LC only helped for a handful of days at a time. Suspecting chlorine "lock" (even though FC level was what I'd been maintaining), and high phosphate levels due to a lot of organic matter dropped from nearby trees and neighboring greenbelt bushes, I tested CYA which had been around 60 at beginning of summer. It was somewhere over 100 according to my test kit. I had water tested at my LPS who read it at 145. I just finished refilling my pool and complete filter cleaning this weekend after a 70-75% drain and thorough brushing. I'm now around 40-50 CYA and FC at 6 having turned the puck feeder to 0 and back to using LC until I decide if I'll go to another method (looking at Stenner pumps). My LPS suggested some "new" CYA-free capsules that go in your skimmers which are chlorine and calcium based. Not sure how this differs from Cal-hypo. Supposedly, my LPS has had good feedback from several of their customers who've used them. Only potential concern reported is the increase in CH that they claim can be managed by regular brushing and backwashing. After my personal experience I'd prefer a pure chlorine method of either sodium hypochlorite or a SWG (except for risk to stone as previously mentioned).
