So much easier to avoid anxiety about your pool when I just check in every week or so.
Can't wait for Fri for you!
YEA!
Now, what comes after pebble?
YEA!
My suggestion, since the stairs definitely have to be diamond, consider a diamond pattern on the bench but use less of them.
Suz, the chemistry is not scary. You've done 100 recipes in your life that were FAR, FAR, more complex. Don't make me fly to Houston and prove it to you. (I'll make you come to Hobby and pick me up).![]()
Suz- just the opposite for me! I'll take Hobby (20 min drive) over IAH any day! That's a nightmare drive for me whether it's on 59 or 45!
Secondly - when they installed your glass tile I thought (didn't go back and confirm) I saw they used a white thinset as specified in the lighstreams installation instruction. On the glass tiles below your waterline tile, it looks like its a different grey product. What was the reason? Is it because one is in the water? Do you see any color differences in the glass tile between the different installation methods? Only ask because they'll soon start installing my steel blue. The tile team said they typically use a grey thinset. I was going to force them to use what is recommended in the lighstreams installation instructions.
Now, today's few tiles will be installed I bet without the thinset and only a two day cure time. All of this could have been installed weeks ago, if someone had acted when I called and called about it!!!!
Take care.
Suz.
(You'll have to come to Hobby and pick me up.)![]()
Bush! It's about 30 min drive and easy in and out! I'd rather poke my eye out than drive to hobby! So when are we planning this trip?
