- Aug 1, 2021
- 63
- Plaster
- Pentair Intellichlor IC-40
We finished our build earlier this month and filled on 4/4. I took over the pool last week and started testing using a TF Pro salt kit yesterday. Results from tonight's test are below. The pool has been crystal clear since it was filled.
pH was off the scale (bright fuchsia) both times I tested with the TF Pro as well as the AquaChek test strips provided by the PB. I checked pool math and started by adding a quart of muriatic acid. Let that circulate for a while, restested and added another quart. TA went from 100 to 70 without any noticeable change to pH.
I retested tonight and the pH is still really high, should I keep adding acid despite the quicker drop in TA? I find the daily Cl and pH test to be the hardest to gauge so far given the subjectiveness and variation from ambient lighting. Still there's no mistaking how far off the pH was
Side notes:
I've noticed what appears to be scale (first pool, very new to this) when cleaning the skimmer basket. There's a rough, salt like deposit on the basket. Anything to worry about yet?
PB acknowledged that they went a little heavy on the salt by accident. Chlorinator reads 3650, TF Pro was much higher at 4400.
TIA!
JB
Build Type: Plaster
Volume: 9000 gallons
Latest Test Result Summary:
FC: 2.0 (2 hours ago)
CC: 0.0 (2 hours ago)
pH: 8.4 (2 hours ago)
TA: 70 (2 hours ago)
CH: 325 (2 hours ago)
CYA: 45 (2 hours ago)
SALT: 4400 (2 hours ago)
Side notes:
TIA!
JB
Build Type: Plaster
