- Jul 21, 2013
- 65,107
- Plaster
- Pentair Intellichlor IC-60
I can bring out a bench power supply instead of fiddling with a transformer. Is it just a relay inside, power = open, no power = closed?
The gas valve is opened by 24V put on it and is spring loaded to close when power is removed.
A gas valve can become clogged with sediment or rusted if the gas line is not properly installed.Are there any safety issues that could be present that would push me to just buy a new gas valve, or if I ensure closure and opening I am good??
See if your gas line and sediment trap is correctly installed as described in Heater Maintenance - Further Reading
If you are are replacing the Air Flow Switch, Pentair sells it as a kit for around $80 and it includes the tubes.Also, any tips on the vacuum tubes to use to replace the ones on the valve and blower? Are they standard, or do I need to purchase Pentair air orifice ones?Regardless of the operation of the valve, I should probable replace these, they appear to have degraded over time.
