Hi everyone, I'm new here. We bought a house last year with a pool and the IC40 never worked correctly. The owner told me she just used a floater with a tab in so that's what I've done. I tried to get the levels right but it always over chlorinated. Even when I had the IC40 at the lowest setting it over chlorinated. The owner had the same experience which is why she used the floater.
But about a month or two ago the lights on the IC40 went out. I checked the fuse and it looks good. The board has a green light. When I flip the pool pump switch the IC40 lights blip quickly and then I don't get any lights at all. Here are some pictures. I ordered a new IC40 last night and it will be here Saturday but since the fuse is not out I'm thinking maybe the transformer. The wiring on the left is where the pool pump power comes in. There is a breaker in there but it isn't flipped. I did turn it off and on to make sure but still no luck. I appreciate your help! -Tim
