As has been mentioned before, I am new to pools in general. I just had to have my IC40 replaced. I have noticed that even when the pool is off, the IC40 still has power. The flow light is red, and the salt good and low lights alternate due there being no flow. I have the Easy Touch system with the remote. I don’t think the IC40 should be on when the pool is not running, correct? If not, how do I wire it up to run only when the pump is running?
Thanks
Thanks
