- Oct 10, 2022
- 54
- Plaster
- Pentair Intellichlor IC-40
Hi everyone,
I think I know the answer but I wanted to make sure I wasn't missing anything. We have a Dolphin S200 robot that has been working well for almost 5 years now. Our pool doesn't get much leaves/large debris. Robot is flushed with fresh water and put away after use.
Today when cleaning the pool, the robot starts up and moves for about 2-3 seconds then stops with no other activity. I've taken it apart and noted the following:
- impeller is clear
- drive motor turns the wheels forward only for 2-3 seconds
- LED does flash normally for a few seconds then no more
- servo arm for impeller motor over back and forth once then no more
- none of the cog wheels appear stripped or visually damaged
I disassembled the entire robot and confirmed no blockages around drive train, wheels, or internals.
I removed the entire motor housing and even popped off the 2 latches holding the drive motor in place. O-ring appeared intact and as far as I could tell, no water inside the main housing area. The drive motor appeared visually normal with no rust or discoloration on the exterior. The desiccant pack inside seemed intact.
From what I've read, I have 2 options: either buy a new robot (what I'm leaning to), or try replacing the motor/motor assembly unit. From some general searching, replacing the entire motor housing is listed between $400-$500 although I guess I could try to just replace the drive motor only. With the number of o-rings in the housing and general wear/tear, it seems the better choice might be to replace the entire robot.
I'm not sure if I can upload a video to the forum, I have one that shows the drive moving and what appears to be a faint high-pitched whine in the background. Not sure if the whine is normal or consistent with the problem I'm having.
Happy New Years to everyone and many thanks for any feedback and advice.
Tony C.
- impeller is clear
- Printed label indicates date of manufacture 4/2018.
- Motor housing has indicated "P2L" and "P64195."
Tony C.
