I under stand I cannot run the heater to help with freezing issues, or to maintain the pool below 68. But we have a spa which can be isolated and heated separately from the pool. I expected to be able to put it in spa mode and heat the spa to some really warm temp and maintain it there for some hours, then return to normal pool mode with the heater off. With this scenario, the heater would light up with cold water at first, then stay lit until the water is say 90 degrees, which won't take long. Then maintain at 90 for awhile, then shut off. Do you think this is safe, or a problem? BTW it's a Jandy 400k BTU gas heater.
