Another Baquacil to Salt Conversion with several questions.
mknauss
42,152
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Add liquid chlorine. Get to target range for your 70 ppm CYA - FC/CYA Chart
Set up your SWCG to generate 4 ppm FC per day. Test FC each day (preferably right before the SWCG starts each day) and adjust the SWCG to keep the FC in the target range.
RidingMann
Active member
Aug 11, 2019
37
Cumming, GA
Cya dropped to 50 today. I assume it’s normal for it to fluctuate a little this early in the conversion?
On another note, we’re going to get this thing right just in time to winterize. ??‍♂️
ajw22
26,604
Northern NJ
Pentair Intellichlor IC-60
Cya dropped to 50 today. I assume it’s normal for it to fluctuate a little this early in ...
What was CYA before? I don’t see tests logged in PM. Just chlorine additions.
CYA testing has a lot of subjective variability.
RidingMann
Active member
Aug 11, 2019
37
Cumming, GA
I didn’t log it, but it was posted in here.
It was 65, you said it was 70?
Anyway, we added 2.5 lbs (per the chart on the back of the stabilizer). Will test again this evening.
ajw22
26,604
Northern NJ
We round CYA test up. If the dot disappears between 70 and 60 we call it 70. You can't judge what 65 is. The scale is logarithmic, not linear. Halfway between the lines is not 5.
Reactions: RidingMann
RidingMann
Active member
Aug 11, 2019
37
Cumming, GA
FC is 2.0
Cya 70
SWG on 80%
Hmmmm. While we’re certainly making headway, I would like the SWG to not be working as hard.
What am I missing?
Edit- pump (and SWG) runs 24/7
mknauss
42,152
Laughlin, NV
Fiberglass
You are creating 4.7 ppm FC per day for your pool volume.
That is on the high side.
Raise your FC with liquid chlorine to the upper target range for your CYA.
See if the FC stablilizes. Otherwise, something is in the pool water that is consuming more FC than just the sun.
Tracey R
219
Boerne TX
Answers in bold.
For now, we're going to turn the SWG back off, continue to test and treat hourly, and hope we get less FC loss tonight.
We just got back from WalMart buying an additional 21 jugs of bleach.
If there is a Home Depot near you, they have LC at 10% (3 gallons in a box) for approx $10. If you buy 4 boxes the $ goes down a smidge. My SLAM went on for a month but my pool was a total disaster due to CYA (it was at 190).
Y'all are doing great. Keep up the work as best you can and it'll get there!
RidingMann
Active member
Aug 11, 2019
37
Cumming, GA
We finally got around to testing the salt today with the K-1766, it was 2400. We added 200lbs of salt.
My question is, will a low salt count contribute to a low FC reading? We passed the overnight FC test with only a .5 loss when we switched the SWG on.
CYA is still maintaining at 70.
mknauss
42,152
Laughlin, NV
Fiberglass
As long as the salt content is high enough to satisfy the SWCG, it will generate approximately the same amount of chlorine.
