Moved from the Deep End thread: The Zero Alkalinity Acid Treatment
Wanted to confirm the numbers calculated above. Using the Pool Math App It shows that much more Acid is needed to get to Zero Alkalinity and 4.5 pH. Starting with 100ppm of Alkalinity and 7.4 of pH 4 gallons of 31.45% acid will get you to 5.85pH. To get to 4.5pH it says I need 16 gallons.
