On the FAS-DPD, I have the TF100 kit, but it is the powder you dissolve then use the drops to make it clear. I believe it is the same process on the K-2006.
I have salt water, so I only use liquid chlorine when I need to quickly add chlorine (pool parties, had the SWCG set too low, etc.). I have my SWCG set to make ~4 FC per day and that has been working fine for me the last few weeks. If yours is also using 4 FC a day, that would be about half a gallon of 10% chlorine per day.
A gallon of 10% liquid chlorine in your pool will add FC of 9. Either your chlorine is weaker than advertised, or you have algae burning up the chlorine as well (even if you cant see it).
So, Friday night I did the OCLT test, results below. It must be that my pool is blasted with sun from sunrise to around 630pm that the chlorine burns off so fast. I think ill do 1/2 the chlorine in the morning and 1/2 around 6 to keep the levels more stable.
Friday 9pm: FC 5.8, CC 0.2
Sat 6am: FC 5.6, CC 0.2
Sat 11am: FC 3.4
