Came back after being gone for a few hours and I see the left wall of the overflow spa is not plumb - Its the first thing I notice when I look out at the pool. I grab my level which confirms my suspicion. The entire length of the left wall is the same. On the opposite side of the spa the wall is plumb. The back wall is off as well, not as bad. The front facing wall is plumb. The gap is big enough that it can't be corrected with mortar when setting the glass tiles. What could be done at this point to correct it? Any advise here is appreciated.
Also, they left zero edge around the AVSC main drain. Doesn't the Pebbletec need to surround the drain in some capacity? The top edge of the drain is completely flush with the shotcrete.
I feel that for 13k the job should at least be plumb - Am I being difficult?
Thank you
Thank you
