Hello all,
Over the past four years I have been trying to maintain my pool with the TFP method and it has been going relatively well.
It has been pretty low maintenance and I enjoy very clear water, but if I don’t brush or miss a day of chlorine I’ll have some algae on the walls. As long as I brush once or twice a week and stay on top of FC my water is always crystal clear.
I understand I must do a SLAM and I understand the importance of removing every nook and cranny of algae. The problem is that my pool is at least thirty years old with lots of stains and plaster damage that provide plenty of places for algae to hide. I also have a big crack between the spa and the pool that water can transit through. I have plaster blistering on the stairs and every time a piece comes up there is some algae growing underneath it. Plus my bottom drain has algae in it that I can see through the cover but I can’t remove the cover to brush it because the screws are stripped and corroded.
I understand the SLAM and TFP method seems to work if you have a perfect pool, but how do I attain those same standards when my plaster feels like sandpaper and is falling out in places. Impossible to remove every bit of algae.
My CC is 0 and I will be doing an OCLT tonight and post tomorrow. I am also ordering a new set of chemicals for TF-100 as mine are over 2 years old.
Is it time to re-plaster? Can you maintain a relative TFP method with a little more brushing and physical attention? Or am I restricted from being a true TFPer until I can get my pool more manageable.
Jake
Jake
