Alkalinity vs adjusted alkalinity?
Dirk
6,855
Central California
You'll need to let us know how you're getting the numbers, as in: pool store results or test kit results (and which test kit). Something to put in your signature, along with all your pool and equipment spec's (hint, hint)... Come on, you've been here a while, you know the drill...
jcaj558
81
New Lenox, IL
I’m getting the numbers from my Taylor k-2006 kit which indicated in my signature along with pool equipment and such. Is it not showi
I’m getting the numbers from my Taylor k-2006 kit which is indicated in my signature along with pool equipment and such. Is it not showing up?
Mdragger88
1,274
Hernando, Ms
Fwiw - I don’t use adjusted alkalinity - I don’t think anyone here does- its a poolstore thing..
Recommended Levels
Are based on true total alkalinity.
If you’re cya is in line w/ tfp recommended levels - the adjustment shouldn’t be that large/matter that much anyway
Reactions: jcaj558
