Alkalinity to low?
heikejohn
343
Cedar Hill, TN
Had to SLAM my pool after opening & only tested PH and CYA before starting.
After 2 weeks the chlorine is stable and I ran a full test.
FC 6
PH 7.4
Alk 30-40 ( full light pink at 30, darker pink at 40)
C Hardness 50
CYA 30
Water temp 69
Do I need to raise the Alkalinity with baking soda? If yes, by how much?
Thanks in advance for your insight.
If the pH is stable, no TA rise is needed. When you add some more CYA (to 40 or 50 ppm) your TA will rise some from that.
Tablets are very acidic. So if you are going to use those, add 30 ppm TA worth of baking soda before using the tabs.
