I did stay true with starting with a TA of 50 but it was so low on the scale I decided to try matching it to my CH so I had one number to remember but I am realizing it does not work like that. Regarding the CH I decided to follow the directions in the manual by staying away from the maximum CH limit which is stated to be 150....I read that after the post you are referring to. Then once I got my K-2006 kit the Watergram starting making me plug numbers in.
You are right I do not know what I am doing but I am eager to learn, so I will state my current goals:
-Have a stable pH within range for my body (7.2-7.6)
-Not exceed the ranges recommenced by my manufacturer.
-Use the least amount of substances in my water (calcium, etc)
-Target the best possible saturation index which I do not understand.
Basically the poolmath calculator is a better version of my Taylor Watergram wheel? This stupid balancing wheel is what made me start playing with my levels. The saturation index was a whole new variable thrown at me.
I see. Couple things. First, you'll need to realize we ignore what manufacturers say in some regards. Second, you can skip the balancing wheel, because PoolMath does that for you. Third, relax, it isn't hard, just have to learn a couple things then it's easy.
QUOTE=pinkfloydeffect;1370152]
Good to know. So when aeration brings the pH up is that only for that session or does it continue to rise each day after use higher and higher? I would assume it will rise to a cap for that session only then fall after use?
I only read once here to keep Alkalinity at 50, everywhere else including my manual, test kits, Google, chemical bottles, all say 80-160ppm.[/QUOTE]
My own experience is still limited. I don't use a lot of aeration, because my inflatable tub only has bubbles but no jets, so it's pointless. It is good for aeration though, if needed. So I started off around ~250 TA (alkalinity), and brought it down with acid/aeration. Out of the tap, I had a pH of 7.3. After 30 minutes of aeration, it was over 8. I would add acid, it would drop down into the low 7's, and 30 minutes of aeration would bring it back over 8 again. Once I got the TA down to about 50, this stopped. Actually I overshot and had a TA of around 40, and aeration wasn't bringing it back up past 7-7.1, so I added some washing soda (baking soda would have worked) and aeration to get it up to 7.4. It dropped later, probably from dichlor, down to 7 again, and I was able to bring it back to 7.3-7.4 with aeration alone. Seems to be pretty stable around 7.3 right now, though again I don't have much aeration.
Very good to know! No wonder my skin feels like an itchy sun burn. So after balancing my water I need to keep up on not only FC between each use but also adding acid between every use it sounds.
Perhaps. You should check your pH often, perhaps before and after each use, while you get things settled. Once you get closer to a TA of 50 I imagine your pH rise should go way down, and make adding acid less needed.
I feel like I should drain my tub again and do a refill, I used the water softener last time and added garden hose water to raise the CH. I will probably be fine with using 100% garden hose aka unsoftened water. I will check my tap CH again hopefully it comes in under 150.
I did suggest that in your previous thread.
Again, ignore the manufacturer here. Target is roughly a minimum of 150 ppm according to the sticky. Mine is roughly 275 ppm. If your tap water is 150, or 250, that's fine, use it.
What does an alkalinity of 50 do to your CSI?
This is one of the nice things of PoolMath, it answers these sorts of questions. There's two columns, a "Now" and a "Target" column. Do a water test and fill in all the values in the "Now" column. FC, pH, TA, CH, CYA, Salt, Borate. (If you don't add salt, just put that to 0, and same for borates). Fill out the values in the "Target" column. This does two things. First, and most obvious, it tells you how to adjust a specific item by adding "x". But secondly, look back at the CSI. Note it has two values, the same "Now" and "Target" values everything else does. These are calculated from all the various "Now" and "Target" values you've filled out. Want to get a specific CSI? Play around with the various "Target" values for stuff and see what the CSI would be for that combination. Don't for get to add temp, since that makes a difference. And since you have a fiberglass spa, as has been mentioned, anything between -0.6 and 0.6 is fine. (I think mine's been around -0.4 to -0.3)
