I am having an issue with cloudy water, and i think i need some help. I've been using the methods on here for years relatively problem free. Indoor 36k gallon pool, plaster/concrete bottom with fiberglass/vinyl sides. Pool is nearing end of life and will need refinished in the next year or two. I went to open for the year, cleaned the pool real well, had a calcuim ring, cleaned that off, shocked it, My water is very cloudy. I have thought maybe its time for a drian/refill but decided to go to the local pool store first ( yes i know, pool stores bad, but i feel i'm little over my head here). They are saying that doesn't need done.
Pool store numbers were
7.9 ph
6.5 Free Chlorine
8.6 total Chlorine
214 Total alkalinity
153 calcium harness
792 Phosphate
They say the alkalinity is the issue. SO i use Muratic Acid to lower Ph and TA, ph dropped to 6.8 (which is lower than pool calc said it would be) and TA only dropped to 180, pool is still cloudy. More Muratic Acid to get TA down more? Thoughts?
7.9 ph
6.5 Free Chlorine
8.6 total Chlorine
153 calcium harness
792 Phosphate
