Algaecide usage
gorocket1981
159
Montreal, Canada
Hello,
Are you using algaecide on a weekly basis? Like Poly 40% or 60% ?
Si you think it is required or just a good thing to do and prevent?
Also just to confirm, in the methodology weekly shock is required? Only maintain chlorine level according to CYA level and SLAM in case of issues? Is my understanding ok?
Thanks
jblizzle
43,238
We generally do not recommend the use of any algaecides on a weekly basis nor is there a need to shock on a weekly basis. The methods we teach here are to maintain proper chlorine in your pool as a function of your cya level at all times.
Jimrahbe
17,077
Bedford, TX
1981,
I think you have missed the whole point of what we do...
If you follow the TFP pool care process, and keep your FC and CYA at the proper ratios, you never get algae, you never need to "shock" your pool on a weekly or any other basis, you never need to add phosfree or algaecides, and you never have to SLAM again.. unless you let it turn green when closed for the winter.
gorocket1981
159
Montreal, Canada
Ok. Thanks. That was my understanding but I wanted to be sure that I understood properly and that I didn’t miss something. I am new to this method after spending a lot of money in pool stores in the past years.
It appears too good to be true!! ;)
Reactions: justinc
gorocket1981
159
Montreal, Canada
Following my initial question, since I already have the algaecide bottle opened, is it ok to follow the weekly recommendation instead of putting it in the garbage? Will it harm something?
Richard320
22,919
San Dimas, CA (LA County)
If the algaecide is Poly 40 or Poly 60, save it for winter closing. If it's something else, don't use it at all. Some of them react with chlorine and get depleted while depleting chlorine. Some leave copper stains and green haired blondes.
