Hello, all. I'm draining our plaster pool for the first time in over 7 years. The dissolved solids have been off the chart and algae has been increasingly difficult to control. So while algae has not been an issue to brush off while submerged, it's not coming off even with brushing once it's dried (whoops!) The pool is still slowly emptying, so I plan to step into the shallow end to attempt to remove both green and mustard stains. Will spraying bleach directly on the stains damage the plaster or even work? I want to avoid having it acid-washed if possible. Any advice? Thanks in advance.
Larry
Larry
