I have been using the TFP method for the past 2 1/2 years and have done weekly testing religiously. I have used the slam process successfully several times but this time I am struggling. Last weekend I noticed what I thought was a small amount of algae in several places. I believe my FC was low compared to the CYA. Pre slam test results (SWG)
PH 7.4
FC 5 CC 0
TA 70
CH 450
CYA 80
Salt 3200
I started the slam last Saturday using a level of 31; testing and adjusting every 3 hours. I had to work Tues and Wed so had to pause the process. I am not able to pass the overnight test. I don’t have the results from early on but the last 2 days I have lost 4.5 and 6.5.
— It isn’t making sense that my results have gotten worse. I noticed my R871 has a best by date of 9/19 so I will get a new one today.
—The pool water looks very clear.
—I am in central Florida. We did have a tropical storm pass thru end of last wk; 4-5 inches of rain
—I have read the slam docs many times and believe I am following it correctly; pump running 24/7, vacuum, brush and filter clean daily
Any advice is appreciated.
PH 7.4
FC 5 CC 0
TA 70
CH 450
CYA 80
Salt 3200
